MATLAB-SQL-JDBC
MATLAB-SQL-JDBC
Hello All,
I was able to connect to SQL from MATLAB using JDBC connection as follows
java.lang.Class.forName('sun.jdbc.odbc.JdbcOdbcDriver');
url = 'jdbc:odbc:mydb';
url = java.lang.String(url);
con = java.sql.DriverManager.getConnection(url,'guest','guest');
statement=con.createStatement();
qr='SELECT * FROM var';
rs=statement.executeQuery(qr);
i=1;
while(rs.next())
result_set.getString(i)
i=i+1;
end
Now, I just want to connect directly to MySQL database without using a ODBC connection.
for example
java.lang.Class.forName('sun.jdbc.mysql);
Does anyone know how to do it?
Thank you
matlabeer
i=1;
while(rs.next())
i=i+1;
end
for example
Thank you
matlabeer
