environmental stress screening of electronic components
presently COTS (commercially off the shelf) components are prefered than MIL approved components, due to cost, availablity and other factors. Environmental steree screening (ESS) is carried out on these components to weed out the infant mortality (i.e. to remove the components which are likely to fail early). In practice ESS is carried out at various levels like component level, card (PCB) level and module level. MIL-STD 2164A gives general idea about the ESS. But the following quiries are not clear. please any one may give some insight.
(a) what is the significance of ESS at these various levels.
(b) What should be the severity of ESS at various levels.
RE: environmental stress screening of electronic components
TTFN
Generally, We carry out thermal cycling with 5Deg.C per minute rise / fall in temperature for 10 cycles for a module with pre and post vibration. In case of PCBs thermal shocks used to be given. The severity of temperature at high or low depends on the modules / PCBs. In spite of these, is burn-in necessary for weeding out the infant mortality. If so at what temperature we should carry out burn-in of module / PCB .
Further what is the merit / demerit of HASS (Highly Accelerated Stress Screening) over ESS.
HASS is an alternative approach to simple thermal acceleration of reliability failures. Application of voltage and temperature is supposed to aggravate failures in weak and potentially unreliable parts. Naturally, there is little evidence that such efforts buy real reliability, since there is little motivation to spend scads of money to test to fail for complex systems. So while the parts that do fail during HASS are indeed weak, it's unclear whether such parts would have actually been reliability failures in the field.
TTFN
