Heat exchanger installation advice
I have a problem to include a heat exchanger in an analyser skid but this is outside my experience due to the temperature.
This is for base oil.
The process temperature is at 250-290degC and I need to reduce it to around 100degC. (20 litres per minute flow).
I haven't yet got the coolant service details from the client and I am concerned as to what would be usual in a refinery as a coolant and what special safety considerations there are.
If anyone can offer some advice it would be appreciated.
RE: Heat exchanger installation advice
helpfull comments and though I'm sure the problem will return in the future, in this case the end user has now decided to install after his main process cooler... thankfully, I now have an inlet temp of below 100degC and am back to using cooling water.
JMW
www.ViscoAnalyser.com
