Pipe Pressure
Pipe Pressure
Could anyone tell me how can I calculate a pipe working pressure knowing its schedule and its geometry?
thanks a lot
thanks a lot
RE: Pipe Pressure
RE: Pipe Pressure
Design stress depends on the material you use and the design code you are working to. The maximum advisable design stress at ambient temperature for common pipe materials is 2/3 x the materials yield stress.
The pipe thickness should take into account thinning, usually 12.5%. and any corrosion/erosion allowance.
However pipework is seldom designed to its maximum capability because there are too many other unknown forces, such as pipe flexibility, cold pull caused by residual stress from welding. Pipework can also be subject to overpressure so it is not a good idea to design it close to its limit unless all these other factors are considered carefully.
John Dyson www.gowelding.com
RE: Pipe Pressure
SQRT[((R-H)^2 + (H-A)^2 + (A-R)^2)/2]
For thin walled pipe, where thickness/Diameter (t/D) < 20
R = Internal Pressure + External Pressure = Pi + Po
H = (Pi-Po)*D/(2*t)
A = [True_Wall_Tension/Area] +(-) [Moment*D/(2*Moment_of_Inertia)]
For thick walled pipe
R = (Po*Do + Pi*Di)/(Do+Di)
H = (Pi-Po)*Do/(2*t) - Pi
A = same as above
where, Do is outer diameter, Di is internal diameter
Design stress = Design_Factor * 2/3 * Yield Stress
Design_Factor depends on load category. Use 1.0 for normal operation load case, 1.2 for extreme load case, and 1.5 for survival load case.
True_Wall_Tension is the sum of applied tension (or effective tension) and end-cap pressure induced tension (or separation force). The end-cap pressure induce tension equals (Pi*Ai+Po*Ao), where Ai=(pi*Di^2)/4 and Ao =(pi*Do^2)/4.
For more information, please refer to API-Recommended Practice 2RD Standards
Hope this help,
