Combo Box Header
Combo Box Header
In VBA, a regular ole Combo Box control has a ColumnHeads property to display Column Headers (if you make it true).
Is there a way to put the text in the header? If you make this property true, it puts a blank row (no text) in there at the top.
RE: Combo Box Header
So no Excel data to use. Does it have to get its data from "a table", to use the ColumnHeads property?
The situation doesn't have to stink.
(Or change "invisible Excel spreadsheet" to "database" if you are more comfortable with databases)
