Anyone know what this "Generator Transfer Switch" is for?
Based on the manufacturer and description, does anyone know what this item would be used for? Is this a good price?
http:// cgi.ebay.c om/ws/eBay ISAPI.dll? ViewItem&a mp;item=17 0025241352
Thanks...
http://
Thanks...
RE: Anyone know what this "Generator Transfer Switch" is for?
http://ww
Looks like a 200A 4pole 2 position switch,
It can be used to manually select beetween two source to feed a load. You mention one your question's title.
Why would u ask the question? What are you looking for? Why ask for this particular item?
1) those switches can be ordered 'break before make' or 'make before break' and that needs to be specific for you application. Make before break would require the generator to parallel normal power, not typical for a small unit.
2) the max current rating is probably not achievable at the max voltage rating.
3) it would need some enclosure and check UL listings specific for the application.
We have recieved similar switches packaged in enclosures as UPS external maintenance bypass switches and if proper for the application they are amazingly compact and capable.
