error msg:close topmost modal form
I'm attempting to write a vba program to open all the drawings in a directory. It opens the first drawing fine, but after opening the second drawing it gives me an error message "must close or hide topmost modal form first".
Here is the code:
Public Sub OpenDwgs()
DirName = "K:\_a\A05309\"
DwgNames(1) = "A0530912"
DwgNames(2) = "A0530913"
DwgNames(3) = "A0530914"
For i = 1 To 3
DwgName = DirName & DwgNames(i) & ".dwg"
MsgBox DwgName
Set CurrentDwg = Application.Documents.Open(DwgName)
'(code goes here)
CurrentDwg.Close
Next i
End Sub
Any ideas what the problem is??
RE: error msg:close topmost modal form
Thanks for the help
This how I got around it....
' In order for this to work the Microsoft Scripting Runntime reference must be added to the project
Dim FileItem As File
Dim SourceFolder As Scripting.Folder
Dim FSO As Scripting.FileSystemObject
Set FSO = New Scripting.FileSystemObject
Set SourceFolder = FSO.GetFolder(mypath)
r = 0
For Each FileItem In SourceFolder.Files
r = r + 1
If Right$(FileItem.Name, 4) = ".dwg" Then
Set CurrentDwg = Application.Documents.Open(mypath & FileItem.Name)
Call DoSomething
ThisDrawing.Close
End If
Next
End Sub
