Spring House Pump
Spring House Pump
I have been asked to design a water pump system for a client who wants to feed a decorative water feature in a park. The source of the water is a small spring fed creek or a spring house with 12" of water in it.
I do not want to use the spring house due to its age and constructability issues. Was thinking of a submersible pump in a small pit or a shallow well. Not sure of the water table depth, however with the spring house constantly full, I would imagine it is shallow so a well may be the best fit. Owner does not want to dig to investigate the groundwater depth so I am not sure if it is worth drilling a well.
If I use the submersible pump, how can I divert the creek water to the pit and avoid debris entering the pit? Was thinking a small inlet type structure with grating in the bed of the creek.
Anybody have experience with this? Would you recommend the submersible or the shallow well?
RE: Spring House Pump
If you try to pump the surface water, you are going to have numerous maintenance periodic problems, freezing, debris, sanitation issues, varying water level, etc.
With a well pump, all you will have to do is make sure that you have power.
