IBC 2000/2003 Response Modification Factor R for dual systems
IBC 2000 / IBC 2003 Table 1617.6.2 shows a building response modification factor "R" for a dual system of IMRF (I assume it could be of either steel or concrete
material) with Ordinary Reinforced Concrete Shear Wall as 5.5.
In the same table it shows, R = 5.0 for an Ordinary Reinforced Concrete Shear Wall, R = 5.0 for a concrete IMRF and R = 4.5 for a steel IMRF.
Why is that the R value of the dual system higher than those of the individual systems?
RE: IBC 2000/2003 Response Modification Factor R for dual systems
See: thread507-162685
