Pipe line rupture
Pipe line rupture
What vendors have a program capable of solving transient problem of instantaneous pipe line guillotine rupture?
RE: Pipe line rupture
Going the Big Inch!![[worm] worm](https://www.tipmaster.com/images/worm.gif)
http://virtualpipeline.spaces.msn.com
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
TGNet was an old Scientific Software Intercomp release. I don't know what happened to that one now.
Best regards
Morten
Also they have a free book; “Fundamentals of Compressible Flow” that gives an example calculation set in chapter 8, “Fanno Flow” that may be helpful for validation of the software.
On the negative side, I doubt that there is any significant technical support. But it is free.
Zapster-Thanks for your input. I don't have access to Linux. Note: Fanno is for adiabatic flow with friction and not for validation of transients.
regards
However---
For liquids, there is a possibility that the fluid will go two phase and even choke. The choke pressure should not be calculated by steady state techniques- but by techniques of the method of characteristics.
For gases that initially choke, the choke presssure should not be calculated as a steady state choke condition-but by techniques of the method of charateristics.
Hopefully vendors would use those techniques.
On a past thread for pipe line break, individuals have recommended using steady state calculations for determining exit pressures during a transient. That type of approach will lead to misleading results.
See for yourself?
http://www.advantica.biz/default.aspx?page=322
ht
By the zero at the exit plane, I mean zero back pressure.
This thread should end, unless someone can provide vendor contacts-in which my original question can be answered.
It was at http://www.psig.org/Conferences/conf.asp?year=1995, a conference of the Pipeline Simulation Interest Group. Maybe you could give them a holler.
Larry
