Air-coolers
Air-coolers
Air-coolers
I have several piping analysis under way for air-cooler inlet and outlet piping systems. I have tried all sorts of configurations to try and model in the most realistic way the connections between piping and the air-coolers and the restraints, but I have yet to come up with something that gives me realistic results (compliant to API 661 or not).
If someone knows how to model air-cooler piping systems successfully, some help would be greatly appreciated.
Thank you.
RE: Air-coolers
In the Applications Guide, you'll find several examples of modeling vessels and nozzles.  You model exactly the same way for any sort of "non-rigid" item.  Remember, CAESAR II uses ONLY the "3D Beam Element", which can be thought of as an "infinitely thin stick".  The "3D Beam Element" does not provide the concept of "shell", "surface", or "volume".
If your model of the cooler (pretending it is a big pipe) is not sufficiently accurate, get the nozzle stiffnesses from the vendor, and use this data as "restraint stiffnesses" at the nozzles.  Use a CNODE here so that you can define the displacements of the nozzle (again acquired from the vendor).
Richard Ay
COADE, Inc.
RE: Air-coolers
Dear sir
i am stress and support design engineer  and i have problem in accurate modeling of aircooler in caesar II
please help me for this
best regards
a.sadeghabadi
