Pressurized Piping Blinding Device
I have a vague memory of having seen information about someone’s product/device that can be used to isolate pressurized piping.  No, not a valve; it seems like it was an on-stream blinding device that may or may not have had integral valving.
Am I imagining things or has anyone else run across something matching that description?  If so, please provide some specifics if possible.
Thanks in advance.
RE: Pressurized Piping Blinding Device
dtn6770,
You may be thinking about T.D. Williamson "Hot Stopple" device for shutting down a line to install a valve after a temporary bypass has been placed around the pipe location.
www.tdwilliamson.com
Also check "Hi Stop"
www.teamindustrialservices.com
Oops! My post above did not include:
The product shown at the above link isn’t what you are asking for; however, it may be what you are remembering.  You cannot install the blind under pressure.
Your replies are all appreciated.
A stopple device isn’t the right application.  I’m dealing with three crude oil heaters with common inlets and outlets with the occasional need/desire to take one off-line for de-coking (pigging).  Isolating the furnace to be de-coked has historically has been done via single stop (gate) valve isolation with a blind.  There’s legitimate concern over installing and pulling the blinds with only the single stop valve holding back the process.
As such my quest is to weigh such options as double block and bleed arrangements against other options like the type of in-line (and on-line) blinding device I'm thinking of, if it exists.  Zapster’s Applied Alloys site offers a link for a “Blind that can be used on Pressurized Pipeline.”
Thanks again for the feedback.
Here is the "Slab Gate Valve" that you maybe thinking about.
http://www.spxprocessequipment.com/sites/mandjvalve/product_literature.asp
 Here are various types of line blinding that we have used in various services.  None are actually pressure cut off valves.  There are many other of similar design.  We tended to stay with the Hamer Design
http://www.rmenergy.com/products/hamer_line_blinds.html
http://www.mg-fetterolf.com/english/prod8.htm#
http://www.hendersonindustrial.com/HISlineBLINDpresentation.pdf#search=%22line%20blinds%22
