How to implement a zigBee network
Hi All,
I would like to use a ZigBee network for a home automation.
I read all the literature on the web.
But there is some silly questions that puzzle me.
For instance, if I need to install a lighting system, e.g. 3 light switches..
1/ Do I need 3 ZigBee enddevices + 1 Zigbee Coordinator or (2 EndDevices + 1 Coordinator)?
If it is.It could be expensive for buying 3 ZigBee devices...
2/ How to connect the ZigBee card from freescale or microship for instance to the light switches, is it through the ADC input?
The channel of the input is it specified in the code of dowloaded application into the microcontroller?
Hope you can help me.
Thanks!
Thanks!
RE: How to implement a zigBee network
Gunnar Englund
www.gke.org
Keith Cress
