Multiple lines for custom prop desc.
Whats the best way to do multiple lines for say a
drawing title in custom props? I've seen a tip
that you can type ALT-0010 after the text and it will
give a second line. This way seems a little hard to
control.
RE: Multiple lines for custom prop desc.
Rob, unfortunatly I'm stuck with swx05 with no hopes
of upgrading anytime soon...
If you're stuck with '05 then I believe you're stuck with Alt-0010 (or Alt-0182).
There's a macro that will establish a word wrap length for you in 2005.  I'd put the code here, except it has a form.  You can download it at http://swtools.cad.de.
Thanks fcsuper....worked like a charm...
