Condesate traps in compressed air lines?
Guys,
Do we need to provide condensate traps in the compressor ring mains when the compressed air has achieved a dew ppoint of 3C or less either thru a refrigerant dryer or a dessicant dryer?I was told by some one they are not required as there is very little moisture left in the air leaving the dryer.
Thanks for your feedback.
RE: Condesate traps in compressed air lines?
Going the Big Inch!![[worm] worm](https://www.tipmaster.com/images/worm.gif)
http://virtualpipeline.spaces.msn.com
Do an advanced search on this site. The topic of moisture diffusion was discussed in some detail a few years ago.
rmw
Guidelines by Health and Safety Executive say to install traps for each and every uprising main. When we had been through BSC audit, I did the modification for the existing lines. I never observed any moisture being drained. Leakage became a nuisance and I replaced all the traps by manual valves.
