"ASTM A193 Gr B7" Hydrochloric acid service
On a FRP tank for Hydrochloric acid 32% in ambient temperature, we proposed Hastelloy, but vendor says:"ASTM A193 Gr B7" for stud bolts. Which is better material?
(Outdoor tank, min Amb. Temp = minus 45 deg C)
RE: "ASTM A193 Gr B7" Hydrochloric acid service
Will the bolts be wet by the acid or fumes?  If so, they won't be bolts for long-they're low-alloy steel like 4140.  Which Hast. would be used?
B7 No; Hastelloy C Yes.
We also use a lot of Silicon Bronze in this service for flange bolting, especially in the smaller sizes.
PTFE-coated B7 studs and 2H nuts are commonly used, temperature permitting.  Forget about Hastelloy bolting- $$$ and galling tendency will both be enormous.
Thanks. Your comment are very helpful.
