Thermodynamic Software
I am looking for two FORTRAN programs called BLAKE and BRLCB which were established by the ARL, Aberdeen Proving Ground, MD, to estimate propellant constants (BLAKE) and calculate the propellant´s dynamic vivacity from the pressure-time-data of a closed vessel experiment (BRLCB). The user manuals of both Programs offer the source code and I have a copy of them - but I am to lazy to write it off!
The program I am using at present called HUNTER, which calculates the same as BLAKE works well, too. But the BLAKE results are in better agreement with experiments. I sent a mail to the ARL, but the do not answer.
Can anyone help?
With best regards from Germany
Andreas
RE: Thermodynamic Software
You do realize that it's probably illegal to give these programs, since they're would be most likely restricted by ITAR?  I suggest that you go through some official channels if your usage is allowed by ITAR.
TTFN
I do not agree with You, IRstuff. The reports mentioned are "approved for public release", the source code is listed there and I can´t imagine what may be illegal on handing over these programs? BLAKE doesn´t calculate nothing else then CEA2 of the NASA - it only uses real gases instead of ideal gases.
