Macro
Macro
I have a design table inserted into my assembly that controls the motion of a skeleton sketch. I'm using the design table to drive one dimesion while getting the results of another dimension. The problem is that you have to activate each configuration in order for the design table to record the result of the second dimension. In my case i have 70 configs. Does anyone have a Macro that will do this process for me? or is there an easier way to get this information.
RE: Macro
Can you not build formulae/equations into the DT which populate the other configuration dimensions?
RE: Macro
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: Macro
RE: Macro
