Cutaway View
Cutaway View
I have created an assembly with three cutaway views in it. I put the assembly into drafts and everything works fine. My exploded view is all in tact, the cutaway views are all there, but how do I make the the draft color? I can't find where to turn the draft into a color one to make it easier to identify each part. I am using SE V18 SP7, any help would be greatly appreciated! Thanks.
RE: Cutaway View
When you select a view the main toolbar will give you the option to turn on shading with grey scale or color. Are you not seeing these options in the toolbar?
I don't think you can change the entire drawing to color in one command. Each view must have shading turned on individually.
RE: Cutaway View
RE: Cutaway View
On the properties of the view (right click on the view and select properties), is there any switch available to tell it to not be a draft (quality) view?
--Scott
For some pleasure reading, try FAQ731-376
