Dranetz PowerPlatform 4300 - SRAM Cards
My old 4300 (bought back in the nineties) has a 2 MB S-ram card that seems to work only with Windows 95 qor 98. Lightning killed my -98 computer and when I try to transfer measurement data to my new VAIO VGN-TX1XP (with XP), it does not work at all.
The local Dranetz guy thinks that I should buy a new analyzer from him, but the amount of PQ work I do nowadays makes that a very uneconomical solution.
I am sure many more users are in the same situation. How have you solved the problem?
Gunnar Englund
www.gke.org
RE: Dranetz PowerPlatform 4300 - SRAM Cards
SRAM PC card work around for Windows XP
Insert the SRAM card into the PCMCIA PC Card slot
When the 'Hardware Wizard' appears, select 'Install from a list or
specific location (advanced)'
Click NEXT
Select Don't search I will choose the driver to install
Click NEXT
Scroll through the list of choice and select PCMCIA and Flash
memory devices
Click NEXT
Double click Generic under the Manufacturer listing
Select Generic PCMCIA Memory Card from the Model listing
Click NEXT
Click the YES button when the warning dialog appears, to dismiss
it
Click Finish when the Completing the found new hardware wizard
dialog appears
Restart Windows-When Windows restarts, you should see a new drive
letter and icon from "My Computer" or Windows Explorer
Thanks a lot jnunner!
It worked on first try. It is obvious that the BMI/Dranetz rep didn't want to tell me about it. Eng-Tips saved me a lot of money!
Thanks again!
Gunnar Englund
www.gke.org
jnunner,
I see that you are new to Eng-Tips. You made a very good start. Have you had the same problem as I had? Or was I just lucky that you found my question?
Gunnar Englund
www.gke.org
We had the same problem when the laptop we use had to be replaced. I'd say it was your lucky day, as I was having a rather dull one... ;)
