SA240 TP304L? for Cryogenic Vessel (-128¦C)
According to a senior design eng of our firm, the correct material for this vessel (design temp= 100/-128 °C) is SA240 TP304L.
According to ASME Secc 2D (Metallurgical Phenomena), the only materials which do not show a decrease in the tensile yield nor ductility measured as percent elongation are those listed in tables 1B and 2B from section 2B (non-ferrous materials).
So I conclude that this material (SA240 TP304L) could be used only if impact testing is provided.
I'd like to know what you think about this.
Diego.
Diego.
RE: SA240 TP304L? for Cryogenic Vessel (-128¦C)
rhg
If the MDMT is -186 deg C or warmer impact testing of this material including HAZ's is exempt (see UHA-51 (d)).
Thanks.
Yes, it can but it requires CVN impact testing for MDMT at or warmer than -196 deg C (see UHT-6(a)). For colder metal temperatures, in addition to CVN tests, drop weight testing shall be performed (see UHT-6 (b)).
Diego.
