axels hub
axels hub
axels hub
which the difference between axles with cubes lubricated with oil seaded or lubricated with grease
RE: axels hub
In general, oil is for high-speed applications; grease is for low-speed applications.  Oil requires a higher speed to build up hydrodynamic pressures and float the journal.  Grease is semi-solid and can support a slow-moving load due to shearing action in the lubricant.
Hope this helps.
Don
Kansas City
RE: axels hub
OK, AND IF THE AXLES WORK WHITH TEMPERATURE -40ºDEG TO +40ºDEG ?
Best regards,
RE: axels hub
Consult the temperature recommendations for the lubricant.
Don
Kansas City
