contact with shell elements
I'm trying to generate contact between 2 shells but when I ask a cncheck, Ansys says that I've got an initial penetration due to the shell elements' thicknesses. Is there a way to thicken shell element only in one direction?
thanks in advance.
RE: contact with shell elements
Hi
No there isn't but maybe you can use a shell93 element?
Garry
I think the problem will be the same with shell93 elements since I need to impose a thickness.
but there is probably a way so that the shell thickness does not alter contact solutions...
Hi
Sorry in ment the shell91 ellement
Garry
it would allso work for SHELL181 with the option for cross sections SECOFFSET. For example:
SECTYPE,SHELL
SECDATA,...
SECOFFSET...
Alex
Thank you Alex and Garry !!
I will try both 91 and 181.
