Pick temporary axis fails
I was trying to pick a temp axis on a cylidrical hole in a sheet metal assembly. I was able to pick the temp axis in one part, but not in another nearby. Has anyone run into this.
I have tried using selection filters and creating a reference geometry axis. In this case SW complains that the axis and a nearby one are intersecting.
www.engtran.com
www.niswug.org
RE: Pick temporary axis fails
Have not seen that before.
I assume you are trying to mate the parts?
cheers
Helpful SW websites FAQ559-520
How to find answers ... FAQ559-1091
What happens when you try to select the hole surfaces for a concentric mate?
What happens if you select the axes before selecting the Mate icon?
Do you have the Coincident mate selected when selecting the axes?
cheers
Sorry, using the measure tool, not mate. The part is already mated, just need to move some holes.
TOP
www.engtran.com
www.niswug.org
