Sheet format in pdf
Sheet format in pdf
If I send a drawing to our printer, all the lines come out black. However, if I convert the drawng to pdf and print it, the sheet format lines are very light and some text, like chamfers, is light. The object and dimensions appear correctly. I am using default templates with some small changes.
Is there a setting somewhere that will make all items print black? Otherwise all I can think of doing is to open each format and manually change all the lines to black. Most of the format outlines appear light when working on the drawing.
RE: Sheet format in pdf
