Using parametric text in drawing dimensions/notes
Could someone please tell me what the proper syntax is for inserting parametric text (i.e. annotations) into the text of a dimension or note in a drawing?
RE: Using parametric text in drawing dimensions/notes
When entering a note, there is a Link to Property icon (chain-link and a hand) in the Annotation Manager. Using it will offer the available properties of the current document or associated model.
Also check the Help files for link, notes to properties > Link to Property and link, notes to properties > Linking Notes to Document Properties.
Go to the part, File\Properties\ Custom tab\ Give it a name as for the value you must click on the dimension.
Then in the drawing you can link to that property.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
