Reset to default condition AutoCad 2005LT
Can anyone advise on how to reset to all the default settings an installation of Autocad 2005LT? Is there a "*pref* file that I can delete and it would be rebuilt the next time Autocad is re started?  We have a seat on a common computer and too many "experts" have screwed this up so bad that I would like to reset to a default as new condition.
Un installing and then re installing is a big deal that I would just as soon not try, the originals are all locked up in a vault and taking anything out requires more signatures than I care to think about..
Thanks for your time
Ralph
RE: Reset to default condition AutoCad 2005LT
A trick you can use is to log on as a new user to your machine. Open Autocad (should open with base settings), export the profile and then import that profile as yourself.
"Everybody is ignorant, only on different subjects." — Will Rogers
That would work... except the LT version does not support multiple users... If it would I would have my own profile and the heck with the others.
But thanks anyway
Ralph
Thanks Exxit.
Installed that and it seems to have done the trick...
Ralph
