Drilling a revoled Profile
I have a profile, fully defined, and anchored at 0,0,0. I have revolved the profile and attached a couple of extrusions. I tried to drill the front face of the revolved profile with the hole wizard and I keep getting messages about it can not locate the position, but if I try it from the rear of the unit, on an extrusion, it goes right thru. Why can I drill an extrusion and not a revolved profile? It is just a revolved cylinder. Thank you in advance to anyone with a solution to my little nightmare.
RE: Drilling a revoled Profile
I've had my troubles with the hole wizard in the past so I suspected this wouldn't work for me either, but I'm having no problems.
Sorry.
Select the surface first then do Hole Wizard.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
