steel for -40¦ / +40¦
I have to build a chassis (trailer) and i don’t now if the steel ST 52.3 is the right choice?
RE: steel for -40¦ / +40¦
You should also make sure you select a suitable welding process and filler metal for fabrication of the trailer. As a minimum requirement, I would recommend you follow a recognized code of construction (like AWS D1.1 or ASME B&PV code) for welding and material procurement.
THANK YOU
I work in europe and i have to find a equivalent material.
