Ocean thermal energy conversion
Although the efficiency of an engine operating between, say, 25oC (surface of tropical oceans) and 5oC (hundreds of meters down) is just 7% (= 1 - 278 K/298 K) there are sufficiently large amounts of warm ocean water to consider exploiting this free energy of solar origin.
Can anyone enlighten us on the progress and practicality of OTEC ?
RE: Ocean thermal energy conversion
Epoisses,
Your comment is appropriate, but can one tell what man-made heat engine doesn't somewhat, directly or indirectly, alter "natural" equilibrium ?
I only really looked at the first one. Involves heat exchangers etc.
I'm having crazy ideas like using a giant thermocouple or maybe something utilizing the differences in salinity &/or density (I'm guessing density differences would be too small).
www.enwave.com
For a heat engine with a Carnot efficiency of only 7% max, you'd have to do it on an enormous scale to make it worthwhile. Even if the energy source is free, capital isn't.
Mike
http://en.wikipedia.org/wiki/Solar_updraft_tower
Looks at once vaguely feasible, rather expensive, and really quite intersting.
Cheers
Greg Locock
http://en.wikipedia.org/wiki/Tidal_power
It's been done already.
IJsbrand
Suppose the pioneers on this technology were the Dutch
ht
Geothermal and Nuclear are the 2 exceptions that spring immediately to mind. I guess burning sulfer and similar chemicals would be a problematic third.
HVAC68
