Lightweight Diesel Engine Study by NASA in 1980
If you are an "engine guy" this might be of interest
ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19800011788_1980011788.pdf
RE: Lightweight Diesel Engine Study by NASA in 1980
Thanks.
It makes me wonder if commercial engine program proposals are ever so beautifully documented ...
  and so full of,  ahem, "forward thinking".
Mike Halloran
Pembroke Pines, FL, USA
If you are interested in Diesel Aircraft engines, then check out Centurian Engines at http://www.centurion-engines.com/ or Delta Hawk Engines at http://www.deltahawkengines.com/. The idea of using diesel engines for aircraft use has been around for a long time, but now are much more practicable.
Benz was doing this in WWII, no?
Mercedes Diesels were used as airship engines.
Junkers Diesels were used on airships and airplanes.
Mike Halloran
Ja, das is richtig.
There is some interest in diesels in homebuilts. A friend is even building an RV with a Wankel engine. Many have done this before him.
