Synchronizers and gear oils
I have a few questions about modern synchromesh designs that have been nagging me.
1) How much of a difference does a GL-4 vs. a GL-5 oil affect synchronization and synchro wear?
2) I see some mfrs using more double- and triple-cone synchros and others recommending friction modifiers to add to the gear oil. Is this to make the GL-5 oils synchronize like a GL-4?
Any other comments on this subject are appreciated.
Dave
Dave
RE: Synchronizers and gear oils
Rather than speculate why not try it. You can always go back. Your main concern would very likely shift to operation.
So for example, will using an extra-slick GL-5 wear out the synchros in a tranny designed for GL-4? Even if the GL-5 claims to be synchro-friendly?
Dave
http://www
The autos in question are imports. Most of these trannys appear to have been designed around GL-4 properties, but in the last 5-10 years the commonly available lubes are now GL-5 rated. The manufacturers have revised their literature to accept both GL-4 and GL-5 (rumored to be because of pressure from dealerships, who didn't want the hassle and cost of sourcing GL-4 anymore).
So the question remains, is this a semantic difference, or is there a significant difference esp. w.r.t. synchronizer wear and performance?
Nick
I love materials science!
