Split Field series DC motor Braking
Hello
I m using this type of motor to control the position of wheels and I m using one field controlled by one IGBT ( move left the wheel )and the other field to move right also controlled by another IGBT. The armature is connected to +V and the emitters of IGBTS to ground. The collectors of the IGBTs to the respective fields.
One diode in parallel with the armature + field 1. And another diode in parallel with the armature + field 2.
How do I brake electronically the motor after
moving to one direction ?
I would have to increase the average current from the diodes if i do braking ?
I would need to access the two terminal of the armature ?
Any url explaining this type of motor?
The motor is a Split Field Series DC motor.
Thanks to all in advance
HYU
RE: Split Field series DC motor Braking
