Help with protective relays
Hello, I was wondering if anyone can give me some advice or give me a link for sample testing sheets for GE line relays or other GE or Westinghouse protective relays. I went to the ge-industrial site and found alot of information but some of our relays are not listed. Reading the bulletins for the relays and comparing them to the notes of a retired relay tech is confusing. I'm using an AVO test set. Any help or guidance would be greatly appreciated. Thanks
RE: Help with protective relays
Your local GE engineer and ABB engineer should be able to track down pdf files for any old relays. There are a lot on their websites.
Those old relay IBs come in handy - hang on to any that you get.
