Wall insulation recommendation
You know, it is best to be careful what you wish for.
After all my years of bitching about architects, the shoe is on the other foot.
I have a client who has a metal building, currently only ventilated. He wants to air condition it, not heat it. He wants to use a spray on insulation.
My inclination is to go for R-20 or better. I have started to do research for this and haven't found one that seems to completely fill the bill:
1. Reasonable cost
2. Helps seal the building against air leaks
3. Moisture resistant, helping to provide a moisture barrier
4. Fire and smoke resistant
5. Pest resistant.
Polyurethane seems to be pretty good, except it has poor smoke spread characteristics and from what I see needs to be enclosed in gypboard or some such.
Anybody have a recommendation for a spray on insulation?
1. Reasonable cost
5. Pest resistant.
RE: Wall insulation recommendation
looks a bit smoky though
I looked at the knauf koolduct system some time ago. I was concerned initially as they were quoting a price with and without a UL sticker.
I actually watched them burn a sample of the foam ducting with a torch, and compared it to code compliant ductboard. Seemed less 'smokey' than duct board in my opinion. Just a casual observation nothing scientific.Was a phenolic foam, maybe look at that type of insulation.
http://koolduct.knaufusa.com/
