Installing SW on server for Admin Image
Most of our systems here are installed from an Admin image (2006) on the server. It was the first attempt at this and I didn't install Solidworks on the server. I've read in these forums that that is the best way to go, so I plan to do this for 2007.
Now SW2007 is out and I've installed sp0.0 on the server to do testing using the SolidWorks Installation Manager. I didn't install the new search functionality because I didn't want to install the Microsoft Search tool (I forget what its called) on our server. My question is then; Will I be able to install this functionality on the actual workstations? Or do I have to have the exact setup on the server. I'm also not sure how using the Installation Manager will affect this if at all.
I appreciate any input concerning this,
Craig Sink
Mechanical Engineer
Force Design, Inc.
RE: Installing SW on server for Admin Image
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
I used the Administrative director, installed the admin image through that. I believe there was an option to actually install the software as a usable install, or just create an image....
Craig Sink
Mechanical Engineer
Force Design, Inc.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Thanks...I'll do that when the time comes.
Craig Sink
Mechanical Engineer
Force Design, Inc.
