Print to PDF - first sheet only ?
I'm using a macro in the drafting side (catia V5) to export drawings as PDF, using the function "ExportData" and the type "pdf", but I'm wondering if anyone here knows how to plot only the first sheet of a multi-sheet drawing ?
I have 2 sheets in the drawing, and if in the options I set the PDF export to "one file", it creates one pdf file but including 2 pages, and if it's off, Catia generates 2 pdf files...
RE: Print to PDF - first sheet only ?
Delete the second, third, fourth pdf it creates.  Optionally you could add to the macro deleting the other sheets.
