API 650 Supported Cone Roof
I am trying to find API 650 requirements regarding arrangement of center columns, rafters and girders for given tank diameters. If API is silent on this, can somebody point a website where I can find one.
RE: API 650 Supported Cone Roof
Richard Ay
COADE, Inc.
Typically, a tank will have a single center column up to maybe 60-80' diameter, with multiple columns in circular layouts for sizes much over this, with details depending on fabricator and designer. What exactly are you needing?
The center column (and rafters themselves) do involve some extra maintenance liability, but also lower the initial cost. On a tank of that size, an umbrella would work pretty well.
You can use a columnless arrangement with rafters, or use trusses, but these don't really improve the maintenance aspect. Another option would be an aluminum dome roof.
