Create a 3D surface with constraints at both ends
Hi all,
     The question is about surfacing:
     I want to create a surface wall which joins two 3D surfaces (1 at top & 1 at bottom).The difficulty that there are constraints applied for this middle wall surface.
     For the lower end of wall surface, there is a 10 degree draft angle applied between surface & bottom surface. (relatively easy as this can be done by swept blend, or other commands)
     For the upper end of wall surface, there is a 5 degree angle between wall surface & top surface. The tricky part is that I want to make this tangent to the top surface as well, so that the overall cosmetics appearance is smooth & nice.
      Is there any practical way to do this? If you have any ideas, please let me know. I am looking forward to do this soon.
engmechs
RE: Create a 3D surface with constraints at both ends
Hi John,
    Thanks for the tips, I will take a look at it.
engmechs
