NX3 and IE7
NX3 and IE7
Have installed IE7 and NX3 will not start (Fatal Error).
Any ideas?
Any ideas?
RE: NX3 and IE7
It has been documented on the UGS BBS that it does not work with NX (or much else, yet).
Ben Loosli
Sr IS Technologist
L-3 Communications
RE: NX3 and IE7
RE: NX3 and IE7
RE: NX3 and IE7
RE: NX3 and IE7
it is very likely that the combination XP-SP2 + IE7 interacts in such a way that makes NX4 misworking. In fact, when it was issued, SP2 made several disasters with a LOT of programs...
RE: NX3 and IE7
If one were to do a separate INSTALL of IE7 and make sure IE6 was still able to work, then NX should still work. However, if you UPGRADE to IE7 (overwrite IE6), then it probably won't.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: NX3 and IE7
RE: NX3 and IE7
Regardless, in the NX4 Release Notes section of the Documentation, it states the following:
Windows XP is the supported NX 4 32-bit Windows operating system. Microsoft has discontinued general support for Windows 2000 as of July 2005. Although customers may choose to continue to use Windows 2000, it is no longer tested and it is not supported by UGS. Problems reported on Windows 2000 will be addressed only if they can be duplicated on Windows XP.
I hope that helps. It would probably be in your best interest in the long run to encourage your I/T folks to upgrade your O/S to XP Pro SP2 if at all possible.
Also, you can usually find out all this information on the UGS GTAC support site either by looking in the posted documentation or by using UGAnswer.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: NX3 and IE7
-Derek
RE: NX3 and IE7
I did see a link between WinXP and IE7, I am pretty sure the IT guys here will probably install it (IE7) by default on the XP machines so I chose to ask my question here in a "related" thread, since it seems the only available update I shouldn't do when we switch to XP is go with IE7. We have admin rights on our machines so the users will need to know this information to make sure NX stays functional.
You're right though about the GTAC, I am new here and I don't have the web key account yet to access that information.
RE: NX3 and IE7
Try uninstalling and then re-installing Java, if possible. I've had Java get corrupted a few times on my PC at home and a clean install usually took care of the problems.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: NX3 and IE7
Simply delete the psapi.dll file from the
%UGII_BASE_DIR%/ugii for NX 4
and NX 3:
%UGII_BASE_DIR%/ugii/psapi.dll
RE: NX3 and IE7
RE: NX3 and IE7
RE: NX3 and IE7
What is the psapi.dll file for??
RE: NX3 and IE7
John R. Baker, P.E.
Product "Evangelist"
NX Product Line
UGS Corp
Cypress, CA
http://www.ugs.com
RE: NX3 and IE7
RE: NX3 and IE7
Paul Phillips
Specialty Engineered Automation
http://www.sea4ug.com
