Pipe Sizing Software
Is there any software available for sizing of gas distribution pipework, including pressure drop and multiple burners?
RE: Pipe Sizing Software
must be hundreds of them,
Energy Solutions TGNet
Stoner Pipeline Simulator
WinSim
Hysim
Going the Big Inch!![[worm] worm](https://www.tipmaster.com/images/worm.gif)
http://virtualpipeline.spaces.msn.com
I would also like to recommend Flowmaster.
Best regards
Morten Andersen
I think if I was replacing my venerable MNET (which is no longer for sale) I would probably go with Schumberger's PipeSim, but it is a near thing.
Any simulator that you buy should work for your problem. Always load an existing system and calibrate it for a real set of flow rates and pressures. If you can't match every point in the system to within a couple of psi then either your "known" data set is broken (which happens far too often), your description of the system is faulty (again, real common), or the simulator doesn't have the knobs you need to tweak to match your local anomolies (e.g., particular lines full of liquid). If you can't match your toughest system then run away from that program because you'll certainly eventually need to evaluate a modification to your toughest system and if you can't match current conditions how do you think you'll be successful extrapolating a change?
One uncommon thing I did with MNET is re-calibrate the model quarterly with new data to evaluate the pigging schedule. If a line needed more negative adjustment then we weren't pigging it often enough. If it needed a lot less them maybe we were pigging a bit too frequently. If the calibration process had been a lot harder then I'd never been able to do that.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The harder I work, the luckier I seem
Best regards
Morten
Olga2000 http://www.olgaworld.com/
http://www.energy-solutions.com/pipelinestudio.htm
