Rebar Detailing
Rebar Detailing
We are currently constructing several low rise (2, 3 & 4 story) office buildings. All cast in place with concrete shear walls. The column spacings and beam spans are quite uniform so we are looking for ways to pre-fab the beam cages & slab steel and drop them into place. I recon this could be done by pre-fabricating a beam cage with all full lenght bottom bars and 2 small top bars just to tie all the stirrups in place. The main top bars could be loosely placed inside the beam cage and easily slide thru the column cage once the beam cage is set in place. If necessary we could also slide a few short bottom bars thru the column cage as well. However ACI requires that bottom bars extend 6" into the supports (unless otherwise specified by the Arch./ Eng.) which makes it difficult if not impossible to place a prefabicated beam cage between the column cages or a prefabricated mat of slab steel (bottom bars) between the beam cages. Has anyone found a way around this, surely someone has done this before.
RE: Rebar Detailing
What you are proposing can be done. It would save time, but would probably add additional labor and materials in that you'd have to have more spliced bars to accommodate the insertion of the cages.
RE: Rebar Detailing
RE: Rebar Detailing
