Re-Ordering Drafting Sheets
I have created a complex assembly of parts and am now creating the sub assy drwgs. After creating some dwg sheets, I need to re-order some of them or insert a sheet in the middle of the the other sheets. Is there any way to do this. I have been trying for ages.
RE: Re-Ordering Drafting Sheets
Ciderman,
You should be able to use cut paste in the drawing navigator at the side of the screen. If you had 3 sheets they'd be shown as Sheet.1 Sheet.2 Sheet.3 in that order. If you wanted to place sheet 2 after sheet 3 you could select sheet.2 and Cut it with Ctrl+X or RMB Cut then you can select Drawing and hit Ctrl+V to paste the cut sheet. Then the pasted sheet would be put last in the list.
Michael
swords
