anyone know how to program LCD with KS0070B controller
i currently doing a project interfacing a microcontroller 80C31 with LCD...but i can't get the lcd works ...i guess is the program code is not right...anyone can help?.... the LCD manufacturer stated here is Trident and the list number is TRIMODS1535...is it HD44780 standard compatible?
RE: anyone know how to program LCD with KS0070B controller
<nbucska@pcperipherals.com>
You might want to see the data sheet on the KS0070B driver chip at
http://www.asamicros.com/pub/project_source/ks0070b.pdf
The commands for programming start at page 12 of the pdf file. Its a matter of sending the correct sequence of binary 1's (+5v) to the controller.
As an example 00000001 will clear the display
and 00000010 will return the cursor to the home position.
Any help ?, yes no let me know.
1. It could be your program. Are you sending the characters over & over. You only need send them the once and they should get stored in the LCD RAM.
2. It could be a faulty LCD module. Have you tried any others.
