UG Post Builder samples
I would like to examine sample post builder files to adopt them into our needs ... I am told that the GTAC web server is holding a database for post builders but I couldn't find them in my search ... any help to find this database or any other source is highly appreciated ...
thanks in advance ...
RE: UG Post Builder samples
While in NX manufacturing, pull down the help menu, and from there select 'online technical support'-> 'download nc postprocessor'. This should take you to the UGS postprocessor library. You can then download posts and change as needed.
Ben Eddy
Modeling/NC Programming
Bayview Edison Industries
