Finding Records
Finding Records
Finding Records
Hello Everyone,
I have two forms within Access.  I have a combo boxes on both forms which lists SSN's.  What I want to be able to do is when I select an SSN from the first form once I have saved that record I have a command button which opens the second form when I open the second form I have some code that looks for that SSN and pulls up the data for that SSN in the second form. But when I use the combo box on the second form to select another SSN and I use a command button to go back to the first form the SSN's don't match.  It is only when I pull up the second form and try in go back to the first form I run into a problem with unmatched SSN's.
Here is the code that I use to find the SSN's when I go from the first form to the second form
I have tried to use the same concept for the first form but since the first form is already open/loaded I can't use this method.
Private Sub Form_Open(Cancel As Integer)
Dim getCAN As String
getCAN = Form_PILOT3.CAN
Me.RecordsetClone.FindFirst "[CAN] = '" & getCAN & "'"
Me.Bookmark = Me.RecordsetClone.Bookmark
Me.cboSearching.SETFOCUS
End Sub
If anyone know of an easier way to do this or improvements that I can make with my code to solve the problem I would appreciate it.
Neaka
RE: Finding Records
If you want your code to run when you switch forms you could put it in the form's ACTIVATE event.
I'm not sure that this will solve your problem, but maybe it will be a step in the right direction. Hope it helps.
