Eccentric Load on Column Footing
I have a pre-engineered metal building with rigid frames.  The manufacturer's engineer has stated that they always place the edge of the column footing flush with the edge of the building's turned-down slab.  Since the column is within 8 inches of the edge, this means the column load is eccentric to the centerline of the footing.
Does anyone have a reference or formula(s) that you can share that handles this situation?  Also, since this pour will monolithic, do you account for the grade beam action between column footings?
RE: Eccentric Load on Column Footing
See Foundation Engineering by Braja Das.  He covers eccentrically loaded footings fairly well.  Coduto has another good reference.
I don't normally account for the thickened edge helping with the column gravity load.
What about the grade beam action (turned-down slab) helping with a moment on a single moment column?
