SMEAR property in PCOMP card
What is the meaning of smear in PCOMP card, to define orthotrophic material lay-ups? In which situation, this smear option is used? When I see the Nastran help, it says ply effects are smeared and the stacking sequence are ignored. If stacking sequnce are ignored, how the analysis will be right? Appreciate, experts thro some lights on this topic..
RE: SMEAR property in PCOMP card
I think Materials Sciences Corporation in Fort Washington, PA has an online calculator that will developed "smeared" properties for you. If not, you can write your own...it isn't terribly difficult and there are several books that will help with the math.
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
