remove point at the end of curve/line for better screenshot
In the part design bench or other bench (just not in sketch mode) I noticed that at the end of every line and curve, there are points. These points are part of the line/curve and can't be deleted nor hidden without affecting the line/curve.
Is there a way to remove these points or just hide them for the purpose of taking screenshot without big dots at the end of every line/curve?
thank you
thank you
RE: remove point at the end of curve/line for better screenshot
Derek
