Torsion spring winding tools?
I’m on a quest to safely wind a torsion spring. My search has turned up something called the EZ-Set torsion spring system; however, I would like other possible ideas. I believe the EZ-Set torsion spring system will not work with the spring I’m looking to torque. The spring that needs torque has a 3.75-in ID and will need a max torque of 963 in-lbf.
My first thoughts were to a ratchet system or a worm gear system similar to the EZ-Set system. However, I cannot think of a mechanical device that will be easily attached to a 3.75-in drum or something that does not take up more than 5-in round. If you have seen or heard of anything please let me know.
Thank you,
Jeramie
Thank you,
Jeramie
Cooperjer
Mechanical Engineer
RE: Torsion spring winding tools?
-b
